BTW, if this is this bike
I started a project and got to 90% and lost interest. The frame, forks etc. are 2007 Husqvarna TE450 rolling chassis I purchased a QS 273v4 with 17" alum wheel and had stainless torque arms machined I added new shinko dual sport tires font and rear I purchased the Nucular 24F 500 amp controller...
endless-sphere.com
then note that most LiFePO4 generally is useful for a max of 2C, sometimes 3C if you don't mind fairly big voltage sag (wasted power). (There are some like A123 (which these definitely are not) that can do better than that, but most cannot, regardless of seller claims to the contrary). If you have the datasheet for these cells or can get it from the manufacturer (not the seller since many outright lie about batteries) then you can see what your cells are really capable of
That means that 2p of 25Ah LiFePO4, or 50Ah, is generally good for up to 100A, maybe 150A.
The BMS on the linked bike is 300A, so it will allow two to three times the amount of current that the typical cell is capable of handling.
The controller is 500A, which if the BMS allows that much would be several times the current the typical cell could handle.
Since it says the controller is a Nucular, those should be programmable current limit, so I would highly recommend turning the current limit down to below what the maximum continuous current the cells' spec sheet says they can handle. If you don't have a spec sheet, I'd turn it down to 100A or maybe 150A at most. If there's a lot of voltage sag, I'd turn it down even further. If the cells are pushed too hard it can damage them.
Voltage sag or drop of voltage under load is a good indication of cell capability. If there is no sag then the cells can easily handle it. The greater the drop in voltage as the load increases, the worse the sag, and indicates the cells are not handling the load as well--when the drop is more than say, a tenth of a volt per cell, that's fairly bad, a couple of tenths per cell is not very good and indicates the current limit should be lowered; there is probably significant heating going on inside the cells at this point, wasting power inside them instead of feeding it to your motor and wheel.
Assuming the cells are very unusual and can handle 6C easily, then at best you could set the controller current limit to 300A, which is the max the BMS can handle. Higher means either damaging the BMS, or the BMS turning the output off completely to protect itself, depending on how it's rating and limiting are done, and whether it is working correctly or not.
To use the controller at it's potential, you'd need a much better battery pack than this type of cell can usually provide, or much higher capacity cells to compensate for their usually low C-rate. (these would probably not fit in the existing battery compartment).
