BIKE : 52V X CLASS WITH A DC MOTO CONTROLLER AND S900 LCD .
Had the bike running great Was getting ready to park for the night and I forgot to lock battery. Battery fell out while I was moving it into my garage . I was walking it as it fell out . THE BATTERY IS IN A HARD CASE .but of course . I went to put it back in and turn on the bike and the display did nothing . I pressed the battery meter button and it don't light up and it don't show full bars like it did before the battery fell .And when I plug charger in
It just stays green .
I decided to take voltage reading at the battery connection terminal ( the terminal pin on the outside that connects to bike)
I only get 2.7v - 2.9v at the terminal ..but I know the battery is fully charged because it was just reading 56-57 v on the lcd display
After getting frustrated over not getting voltage anywhere on bike with battery plugged in
I decided to remove the battery and take apart the hard plastic shell case that protects the cells and BMS and see if connection is loose or broke but it looked fine .
I seen that I could disconnect the battery pack from the pin terminal and it also has a USB port and the voltage battery meter chipboard you can disconnect as well when I check the voltage it reads 50.4 v which is better but still seems not normal for a full charged 52v battery
Now when I reconnect to the chipboard with the battery meter and the USB port
Seems like something is shorting out the voltage because it reads the 2.7 to 2.9v again All I see is a USB port and the battery meter level lcd power wires between the pack and the pin connection and when I disconnect those I get a voltage reading but it still don't power the bike
I Tried reconnect the battery without the USB and battery meter chipboard to see if the 50v reading would turn the bike on but still nothing ..
Could this be a bad BMS or Bad cell from the impact.?
The battery case is super rugged I don't see how a fall from the frame height could cause a problem like this ? But maybe it's poor craftsmanship . And my dumb move for not locking the battery .
Maybe someone could help me diagnose this problem or anything to point me on right direction ! Thanks
I can take pictures if that helps
