Mark Peddleman
I’m fairly new to ebikes. 48v battery was stored indoors for more than a year and this year I tried to charge it but nothing happened. Charger only blinked red.
I read that if voltage too low the circuit inside shuts down and has to be awakened. No body would touch it and online info was complicated and dangerous. Someone here tried a trickle charger for a long time and his battery woke up enough so the regular charger now worked with a solid red light. Tried the same thing but with a 36v charger. After several hours blinking red changed the solid red and finished charging till all test lights on the battery lit. Then I put the fully charged battery on the bike expecting all to be normal.
Not quite. Dashboard will not stay on more than a few seconds. Pressing the throttle those few seconds the hub motor would run but only a second or so till the dashboard shut off. I wondered how it would be if I put the 36v battery on the 48v bike. Now the dashboard came on like normal but charge level showed empty and throttle would not get motor to run.
I’m at a total loss as to what’s going on and how to fix it.
I’m hoping one of you guys with more experience and knowledge can help.
Thanks for any helpful information.
