Let's say you use cylindrical 2Ah 18650 cells. Each cell probably weighs around 45g. We'll just toss in 5g of interconnect for every cell (it's probably signifcantly more). (if you find significantly lighter cells they are probably either not as-claimed for properties (or are entirely fake) or the spec given is wrong).
We guesstimated previously you need perhaps 120Ah to get 160A for 30 minutes. So you need 60p of 2Ah cells for that (more really, because those aren't quite 2Ah). At 72v, 20s, that's 20 x 60 cells, which is a total of 1200 cells.
1200 cells x 50g = 60000g, or 84kg, which is about 133lbs. That doesn't include any of the casing, cell separators/holders, etc., and probably doesn't fully include the interconnect weights.
I haven't tried to calcualte the volume this pakc would take, but I would bet that it is significantly larger than the same done with the EIG cells I have, which IIRC are something like 7"x11"x0.25" in their holders. It has the advantage that you aren't limited to cubic types of pack shapes, of course.
Side note: the Sanyo UR18650RX hasn't been tested over at lygte-info.dk, but a number of other Sanyos have, if you're interested in comparing. The ones I glanced at don't have tests higher than 15A, but that's better than what the DNKpower site has for the "20A" cell linked; they only tested it up to 10A; based on how much greater the 10A is vs 5A, the 20A is probably *much* worse sag; at least twice as much. If so, I'd guess they'll sag down to 3.1 or 3.2v (or worse) at 50% SoC.
If that's true, then you'd only have 20s x 3.1v = 62v available at the 160A draw, when the pack is half full (about 3.65v/cell unloaded, or 73v). Assuming the same level of sag at full charge, then instead of about 84v (unloaded) you'd have about 0.55v (cell sag) x 20s = 11v (pack sag); 84v - 11v = 73v, so it would be like having your pack only half full wehn it's really full, at that current draw with that amount of sag.
Without actual test data I couldn't tell you what you'd really get, of course, but it's safer to assume worst-cases and then anything that turns out better is a bonus.
copied from the DNKpower page:
