dnmun
1 PW
use compression on these too.
dnmun said:use compression on these too.
dnmun said:you have to put them in compression to keep them from swelling up. this is common knowledge.
RLT said:As to compression, I'd say that this is a: 'maybe'... It sure wouldn't hurt.' The plastic cases ARE pretty rigid. If you drop one on your foot it is your foot that will suffer, not the battery. I'd say they are more structurally sound than a typical car battery, due to the relatively thick ridges on the sides...
But I did notice that one of my new batch of cells is very slightly swelled. I didn't measure it, maybe 1 -1.5 millimeter of swell at the center on each side. Squeeze them as hard as I can by hand and I can feel a very slight amount of give. right in the center, but not close to the edges.
I'd say, without actually testing; Compress them if you can, but if you can't, don't worry about it too much.
imorton said:....... It looks like all the 28 cells that you got are up to spec and seem to be testing well.
Guess it depends on how much space you have, how much of a craftsman you are and how much money you want to spend.I wonder if I put 4 x 12v 20ah modules how to compress them
So I guess if one or two cells puffed after 3-5 years, you could swap it out for a $35 cell within 10 minutes. That's what appears interesting to me.
Punx0r said:There are a few different batteries available with similar design of plastic cases and they do suffer from swelling and compression is recommended, although they are physically much larger and so less rigid. It's common to see pallet banding applied to the channels in the cases to provide support. You may or may not need compression depending on how you treat them and how they react to repeated cycling.
In your opinion. Respectfully, I believe all pouch cells are begging for some rigid encasement that will hold the pack in compression. Its a battery pack life extending move. The swelling & cell degradation may not show up until closer to the end of the cells usable life and that's when compression will be more necessary.Punx0r said:You may or may not need compression depending on how you treat them and how they react to repeated cycling.
Yes, but not for these cells. Its looking like they've been constructed with adequate compression, from this early testing. By the way, a big thanks for the early adopters, testers & posters.imorton said:Thanks for the info, so it appears that "compression" will have to be incorporated into my battery design/installation..
Thanks for the product reference. I've been looking for this product a while: http://elitepowersolutions.com/products/product_info.php?cPath=47&products_id=212IBScootn said:check out this site to see how GBS bands four cells together:
http://elitepowersolutions.com/products/product_info.php?cPath=25&products_id=92
arkmundi said:In your opinion. Respectfully, I believe all pouch cells are begging for some rigid encasement that will hold the pack in compression. Its a battery pack life extending move. The swelling & cell degradation may not show up until closer to the end of the cells usable life and that's when compression will be more necessary.Punx0r said:You may or may not need compression depending on how you treat them and how they react to repeated cycling.
arkmundi said:Thanks for the product reference. I've been looking for this product a while: http://elitepowersolutions.com/products/product_info.php?cPath=47&products_id=212IBScootn said:check out this site to see how GBS bands four cells together:
- Over 1KWh of energy storage
- 500W true sine wave inverter
- Two 120V AC outlets
- Two 5V DC USB ports
- East wheeled design
- Recharages in less than 6 hours
- 1 year warranty
- Weight: 64 lbs
- Dimensions: 17 15/16" X 13 1/8" X 16 3/4"
The idea is a range extender for when I want to go eBike camping for a few days. I've considered a lot of different approaches, from simply more batteries to building my own such with AC inverters and so forth. I purchased a Duracell Powerpack 600 with some hope. But that product sucked bad. What I want is a big battery pack that I can plug my charger into when needed on the road, but also my laptop computer for connectivity, my cellphone for charging, camp lights, etc, etc. I even have a high efficiency DC powered refrigerator and a new fangled magnetic induction stove. The equivalent of an RV packed into a small light weight bike cargo trailer.
I'm glad someone is making the rather exact Li-ion portable battery I need - 1 kwh, ~83 amp-hours. That's enough for a full day's travel, camp side dinner, lights, etc. Only thing I don't like is its 6 hour charge time.
Hey, thanks for that offer. Maybe. Perhaps I'll re-evaluate. Yea, I've got a window of opportunity for return. The primary question is how many 36V 20ah pack charges can I get out of it. I want to do testing and the only way is to buy one. If its not up to my expectations, I'll return it for a full refund, and eat the li-ion shipping charges back, but worth it. I want two 80%DOD charges of my A123 20ah packs. I sent Rick the specs of my batteries and the charger - he said yes, I should get two. So I've effectively doubled my capacity. 80ah I believe will get me my 70 miles per day.John in CR said:For less weight and money plus a relatively minor amount of sweat equity you get double the capacity that also can directly tie to your bike, and solar power that makes unlimited camping time possible unless you get unlucky in terms of sun. If you need assistance, I'd gladly help put a package together for you.
John
