I checked the polarity coming off the charger, and the #1 pin shows negative and the #2 pin shows positive. So I connected the port to the charger, and the port has two wires coming off it, so I put a female connector on the wire coming off the #1 pin, and a male connector coming off the #2 pin. Male positive, female negative.
I checked the polarity coming off the battery, and the red wire shows negative and the black wire shows positive. So I am (going to) put a female connector on the black wire, and a male connector on the red wire. Male negative, female positive.
This should have the polarities lined up correct, yes?
When I plug it in, if I've got it wrong, is there going to be an obvious sign, other than the battery exploding and setting everything on fire?
