It's been a while since updating this thread. It is going to turn into a long term test of a BBS01 unit, with extensive daily commuting. The commute is not offroad or particularly hilly, so if it can survive this it should indicate a durable commuter for others (under similar conditions).
The unit worked well, pretty much up until 3,500kms. Quiet but powerful enough for the commute without intimidating people, the inconspicuous mid drive is well suited to places where low limits on mid drives are endorsed. I had replaced chain, cassette (with SRAM for linear gearing), brake pads and was considering replacing the front chainring.
However, at 3,500kms, things went south. A 'grr' sound had developed when it was on acceleration and it became more frequent and louder as time went on. After reading up on here, an issue was identified by Kepler, that there is an o-ring on the end of the motor shaft, designed to make it grip the inside of the cassette bearing the end sits in. I took the unit apart and the o-ring had disintegrated and the shaft had been spinning within the bearing.
Photos of disassembly:
After contacting Paul of em3ev, a replacement half a motor was sent and installed. I replaced all disposables - various greases, sealant etc. I should note that other than the detonation of the o-ring and the lack of grease on the needle bearings, all appeared relatively ok inside.
Upon reassembly the motor continued to make the noise and had developed another note. Clearly there was more to the story.
The entire motor was sent to Bafang for reconditioning/repair. Several months later, it was returned and likely a replacement unit rather than repaired, given it's lack of dirt and scratches. Reinstalled in the weekend, works again like clockwork. This is a real testament to the extent Paul is willing to go to for his customers, which I am very grateful for.
I have been keeping a spreadsheet of my commuting, and will to continue to do so to keep track of when issues arise.
