This would probably be an impossible mod without some machining, but I'm going to have to replace the bearings in my hubmotors on the SB Cruiser trike; they're getting pretty worn from the sound/feel of things as I ride.
There are two different front motors (in the rear wheels) which complicates things, too: 9C 2807 and Crystalyte X5304.
The reason for considering cup & cone style is that these wheels see considerable side loads, and I don't think the cartridge bearings (at least the ones that come with them) are meant to take those. But cup & cone often do on regular bike applications, and dont' seem to wear as fast (assuming proper greasing and staying clean of grit).
So, assuming C&C vs Cartridge type would be any better, given that whatever I do either way will have to be done with what I have laying around, I think I might be able to do it using old BB cups for the outer races, if I can find a hardened surface that will work for the inner race over the existing axle, without machining and hardening the axle afterward.
Regular bike axle stuff is way too skinny to use on these thick hubmotor axles.
Another challenge is to be able to set the pressure on the C&C because I wouldn't have a threaded axle to put them onto. I'm not sure how I'd get around this.
But if anyone has any ideas, I'm up for pondering them.
