Bending tube jigs for frame building
Nothing wrong with free, as long as it really does work. But Harbor Freight has some cheap tube benders that I've used before.
https://www.toolots.com/bench-model-compact-metal-bender-with-7-dies-sturdy-and-versatile.html
Hit up the pawn shops for some deep discount savings!
spinningmagnets said:
This first video is cued up at the 3:33 mark, showing how easy it is to bend square steel tubing...
I've used the same method to make consistent large radius bends in round steel EMT tubing. It took a little trial and error to get the desired radius, because the bent tube always springs back to a larger size than the form.
That said, I would avoid bends in frames whose stiffness, strength, and weight are important. Both struts and tendons in a truss or space frame work best when they're straight.
