bowlofsalad said:Apples to oranges. Lets each ride straight out until our battery dies and then see who gets home sooner.
Haste said:watched the vid...and i want one..
Wouldnt it be cheaper just to build my own...for 1600 I feel like I could build 2-3 of em.seems the 2000w(35mph bike) only runs a 48v 12 lifepo. Imagine running 60v and welding a pedal shaft for some faux or real pedals..faster, cheaper, lighter, and more transportable than a 55 lbs downhill ebike.
Ykick said:Haste said:watched the vid...and i want one..
It's nicely "worked" standup in it's class. They appear to have the battery figured out along with BLDC motor in the 1500 model.
Having ridden brutal NYC roads with something in similar class, one of my concerns would be chain size? Is it #25 or something heftier? Put one of us 250lbs old fat riders slinging around those power levels, #25 can/will be a PITA.
But, for reasonably decent road surfaces, 'don't get much simpler than a standup scootet. Tire service video was a nice practical touch, I wish them well.
triggeraa said:These scooter run a beefier T8F chain.
What does that mean?triggeraa said:These scooters are street legal in Cali.
gogo said:I have a 16" wheeled Currie folder and can attest to the utility of being able to pop it into the trunk. My EzGo will fit into the trunk of the smallest car Hertz rents.
I ran my EzGo @56V (stock 24V) and got up to about 35 MPH. While I enjoyed the zippy acceleration over the stock 24V, I'd say you have to pick your path carefully, even with 16" wheels.
gogo said:Nice polish on the video production. Lol, "Its the jizz".
The worst part, though, was the bending force on the long cantilever handlebars. If you had to do a quick stop at high speed, that long stem would buckle. Shame on you for not pointing out the brace on the steering headset in your high speed long range footage, even though its clearly visible. Riding at those speeds without that brace is suicide.
Such a set-up has its place, but it has its limitations, as does every contraption.
I was incorrect about the brace. It appears to be simply a camera mount, and not used structurally to bear the force on the handlebars during braking, as I had thought.vulyone said:gogo said:…The worst part, though, was the bending force on the long cantilever handlebars. If you had to do a quick stop at high speed, that long stem would buckle. Shame on you for not pointing out the brace on the steering headset in your high speed long range footage, even though its clearly visible. Riding at those speeds without that brace is suicide.…
What brace are you referring to?? suicide? please elucidate.
For this to be a truly comprehensive review, and for your own safety, will you would look further into this potential point of failure?HANDLEBARS: Billet Stem - 20" Race Bars
True, my EZGO has no rear suspension, but effectively what this means is I have to rely on my legs and/or seat more for suspension.The Stig said:gogo said:I have a 16" wheeled Currie folder and can attest to the utility of being able to pop it into the trunk. My EzGo will fit into the trunk of the smallest car Hertz rents.
If the EzGo doesn't have rear suspension, I don't know if you can make the comparison to this full suspension scooter...
Good point about the brace, I didn't know what that was...
DAND214 said:What does that mean?triggeraa said:These scooters are street legal in Cali.
No registration, plates or insurance or license?
We need to move to CA.
Dan
gogo said:I was incorrect about the brace. It appears to be simply a camera mount, and not used structurally to bear the force on the handlebars during braking, as I had thought.vulyone said:gogo said:…The worst part, though, was the bending force on the long cantilever handlebars. If you had to do a quick stop at high speed, that long stem would buckle. Shame on you for not pointing out the brace on the steering headset in your high speed long range footage, even though its clearly visible. Riding at those speeds without that brace is suicide.…
Upon further research on the manufacturer's site, I see the handlebar stem is claimed to be:
How long is the lever acting on the base of the handlebar stem?
What is the construction of the stem? Is it solid, as the term 'billet' implies?
What is the diameter and of what material is it made?
How and where is it attached at the base?
Does it bear against a sharp-edged collar?
I notice that the seat is tipped back a fair amount. I'd guess this is to keep your butt from sliding forward and/or keeping some force off the handlebars during braking. You may want to peruse this thread pertaining to the consequences of that practice: You're sitting on your penis
What I'm alluding to is the dynamics of small wheels and short wheel bases. If you support the scooter with the front wheel off the ground and grasp the handlebar with a finger and thumb, you can test the force needed to turn the handlebars. The smaller the inertial moment, the more its up to the rider to maintain the correct steering angle. This skill can be learned and managed to an extent, but the characteristic is less than ideal and for first-timers it can be dangerous.
Short wheel bases combine to make a 'twitchy' feel. The resulting poor dynamics seem to get worse in a non-linear way in relation to speed. What happens is when you get pitched into the air on a bump and are 'disconnected' from the contraption, your ability to control the steering input is less and the possibility of a slight steering input to cause the contraption to 'take- off' in an unintended direction is greater. Much like an E-S member from Russia experienced:
[youtube]lANQ5JdvJ88[/youtube]
Contrast that with motorcycle-type dynamics with a much more stable steering inertial moment and the ability to use your knees to position your body in relation to a much heavier contraption. The motorcycle dynamics are better for higher speeds, at the compromise of low-speed maneuverability.
Every transportation choice is a set of comparative compromises. My EZGO just isn't suited to more than its stock 15 MPH speed and smooth pavement, but given those conditions, .
+1 on that utility and on the utility of their compactness at the end-of-line. I still think they aren't speed-duty compared to an ebike, though.vulyone said:Another advantage I would like to add is mounting and dismounting on and off the scooter is way easier and less stressful than on a typical ebike.
Reality is the ultimate arbiter.John in CR said:"Rules are meant to be broken."
gogo said:That fix by Chris wasn't designed by a structural engineer, I guarantee. Its still inadequate, as is yours. If you could run a solid rod all the way across, it would be a start, but even then the vertical brace needs more meat in that area.
