liveforphysics
100 TW
Currently running 203mm front rotor with hayes hydraulic lever/caliper set, it's a 4 piston fixed caliper.
Modulation is great. Braking power is great. They do everything fine for normal riding.
However, I'm trying to put together a build just for the death-race coming up soon, and after 4-5 hard stops in a row, these brakes are faded and smoking, and once in a while they boil the fluid and I get a limp lever and have to frantically use the back brake.
I never want to have to use the back brake while racing, I just hate them, and only run one as a redundancy. This is because if you're braking hard enough, the back wheel should be on the verge of lifting anyways, so it can't do you any good, but can cause a nice variety of crashes if you lock it by mistake.
I'm not really worried about cost (if it really performs well), but I only have about 20 days left to build this bike, so it's gotta be something fairly available.
Anyone have any super ideas?
I was thinking cable brakes to avoid fluid boiling, and maybe a little duct glued onto the caliper to try and channel as much air onto the pads/disk as possible? I would love to run a pair of disks in the front, and found a chopper-r-us hub for dual disks, but can't seem to find a fork or in-stock calipers etc to make it work.
This is for a 20" wheel no suspension BMX bike.
Ideas? Any super monster disks out there? Double disk setups that work?
