BiGH
xyster said:Since mounting the motor, how much harder do you find it to pedal?
not much - it just feels like i have two panny bags full of bricks
and soon i will
LiPO bricks hehehhe
Mark_A_W said:Hey BigH
How did you go with your rear cluster? Are you using the one that came with the motor? 6 gears?
Does that match your shifter? Looks like a 7 to me?
Is there any room to mount a disc on the other side?
Believe me, you're going to need disc brakes...
Mark_A_W said:Yep, new forks and a front disc is the obvious solution.
I just picked up my new (to me) XC dualy and with discs it stops in less than half the distance of my heavy V-braked E-bike.
Which Lithiums did you chose? Or are you still deciding?
Mark_A_W said:Nup, it's "Nine Continents" or somesuch. I think it's the same factory as Brett's GL2 - looks identical in design, just smaller.
I'll ask about side plates - good thinking 99.
Ypedal said:The controller will run fine without the Ebrakes conected.. ( I have the same problem on just about every bike out there )
There was a guy making ebrake kits that would hook up to regular integrated setups by glueing a sensor on the underside of the brake levers.. but he's been away for a while.
Good stuff !!!! keep the updates coming !!
BiGH said:- 72v 20a controller (with a 72v 35a controller as a backup)...
BiGH said:my normal daily controller will be the 20a until i mod the 35a...
xyster said:I see the upgrade bug has bitten already. :lol:
First post:
Recent post:
BiGH said:whoops sorry the recent post is more correct lol
