Tried to guesstimate charts of what I think I perceive in pedal power.
Approx. power band:
Approx. RPM vs time to exhaustion:
Power vs time to exhaustion:
Unite MY1018:
Right then, I've been thinking the 250w MY1018 could be good if crank mounted with an internal geared hub at back.
The way I would use it is pedalling around 90 most of the time, like when commuting and stuff, and every now & then I'd hammer around 120 for a few mins whenever I want/have to, ie: there's some other dude on a bike I want to beat, I want to ride in with the traffic for some reason, or maybe I'm warmed up and just feel like it, etc... But the point is that pedalling at 120 is something I do when I want to go faster.
So here's the problem: The MY1018 would get revved out and put out less power when I want more of it, or it would be bogged down wasting eff needlessly when I'm using it as I would most of the time, cruising along, because it's power band is ass backwards compared to the human part of the drive line.
Now I'd much rather have something that actually complement the human part of the drive line, unfortunately with the crank drive the only way I could think to circumvent it requires the use of a derailleur to change the proportional ratios depending if I'm cruising or pushing. But a derailleur is something I strongly prefer to avoid. So, the other solution I thought of was to mount it on a geared hub up front, this one has the double advantage of introducing a freewheel to the works, that would be absent in the crank mount config.
