Reid Welch
As I intuit his words, the effect of ultra-low CG on a two-wheeler
will cause, when it breaks away in xtreme cornering, to break away
without feed-back warning to the driver.
Otherwise--no problem.
And it's that lack of warning/feel that makes, I suppose,
the theoretical ground-level CG bike "dicey".
Look at it this way: say the bulk of mass were far below axle height;
at the ground (just for an logical extreme example), then...
the slightest slip of tire grip will cause a sudden flip-out,
just as if a giant boot had side kicked the bike out from under you.
That's just my take.
Safe or other persons, please correct.
My notion may be entirely wrong.
________________
______
addendum: have not read through all the pages in this thread.
Looking at the past few, I come to this practical real-life conclusion
which fits my bike and situation:
-my ride is a cruiser bike. It sets me high from the ground.
I choose a seat-way-back postion (the leaned-back Thud Buster)
and have a reversed high-rise steel stem and lonnng cruiser bars
so...my bike's weight is grossly set to the rear.
70lbs bike, 150 lbs me, weight on the front tire? Is about thirty pounds.
And the bike handles great, it's nimble enough for turns and stable at high speed.
I prefer this because because because when I brake, it's the front brake that I most use, and the dynamic tranfer of mass from front to rear mandates my sitting far back when I brake hard at speed,
because otherwise the pitching forward of weight would tend to throw me,
if not throw the bike.
This is why I prefer and feel safe on a heavily rear-biased bike.
And I find the handling is just grand as it is,
and bear in mind I'm on soft, huge balloon slicks and so traction is never a problem on pavement; it is almost impossible to lock the front wheel in braking because the rubber patch is so grippy,
soft and wide.
Practice trumps pure theory -sometimes-
when it comes downto real-life needs.
My greatest need is to be able to haul to an emergency stop without locking a front wheel.
Putting the weight to the rear, with myself well-back behind long bars,
prevents rear wheel lifting and precludes the tendency body pitching over the bars too.
Motorcycles of 1910 were still bike-like and had long handlebars.
I like that look and I like the security and comfort of my choice of upright stance, etc.
Personal choices overide cold theory often with superior real-life results.
________________
______
soft and wide.
