Osric
- Joined
- Jun 19, 2013
- Messages
- 10
I'm completely new to electric bikes, but decided to fit my bike with a Bionx system after riding a number of choices at the local shop.
I went with the PL350 because it's $300 cheaper at my shop than the SL and the only advantage the shop owner cited for the SL was greater range, saying that essentially the kits were otherwise identical. Now I'm second guessing myself; here are my questions:
- turns out the SL motor is a fair bit lighter than the PL motor; will I be able to tell the difference?
- it seems easy enough to remove the speed limit if desired; will the SL motor be capable of a higher top speed? What are the actual top speeds possible with these kits?
- the SL charger spec looks like it charges almost twice as fast as the PL charger - the PL charger charges at 2A and the SL at 3.75A; will I notice a difference?
Opinions appreciated, as if I'm to make any change in my order it'd probably need to be in the next 24h.
thanks
Osric
thanks
Osric
