deardancer3
How many pins does the cable have that you need?
d
d
There are a number of points to consider...cjr said:[...]If it is a slight downhill or a good tail wind, I spin out and can't get much past 16-18 MPH. (stuck with a 48 tooth ring on front). Spinning at 80rpms, plus, I'm not getting any assist to speak of. I see few/no bars of assist, and when I set the assist to 0, it doesn't feel any different than on level 4.
[...]Now, the real problem is a day like today, we were riding into a stiff headwind, on flat to slight uphill grade, and I couldn't stay with him even on level 4.. but it doesn't seem to me like I am getting anywhere near 300%..
The BionX and other commercially sold systems are required by law to have a speed limiter. It is 20 MPH in the US, and, I believe, around 15 MPH in most of Europe. BionX computes the speed from the motor RPM and the wheel diameter. You can trick the speed cut off by reprogramming the wheel size. That is what you have done. However, the max, non-cut-off speed of the system is only a bit higher than the cut-off speed, so it will not make much difference.cjr said:[...] When I said we changed the wheel size, what we did was change the wheel size settings in the console to try and defeat the speed limiter. [...] If I am understanding your information correctly, the motor has a top speed, which is RPM's, and it won't matter what settings you put in the console, it isn't going to go past that top design rpms. The only way changing the console settings would make a difference is if the motor has excess capacity and it is the settings in the console that are preventing it from reaching that maximum RPM.
cjr said:Alan, thanks for the lengthy explanation.. I thought I should add some info/clarification. The BionX we bought is the PL-350. The Trice-T has a 20" wheel. When I said we changed the wheel size, what we did was change the wheel size settings in the console to try and defeat the speed limiter. We didn't actually change the physical wheel. This was based on instructions in various forum posts we've seen. However, there have been other posts saying that it won't work... Excuse my non-technical layman's wording. If I am understanding your information correctly, the motor has a top speed, which is RPM's, and it won't matter what settings you put in the console, it isn't going to go past that top design rpms. The only way changing the console settings would make a difference is if the motor has excess capacity and it is the settings in the console that are preventing it from reaching that maximum RPM.
