I rode the bike with the eccentric front bottom bracket in the diagonal & foward + down position.
It feels like the seating position goes forward more in this position.
I did some modifications to bring the chainline more inline on the front and rear chains, and cleaned the chains and relubed, and this seemed to make a tiny difference in pedaling efficiency up the 8 mile climb.
Either that or i am developing better musculature, which is possible because i was very out of shape until this month.
The wiggly-ness was half as intense, almost liveable, but felt a little sketchy at 30mph. Disconcerting but not dangerous.
0-7mph cross winds were present.
I notice that most of the wiggly-ness at high speed stops when i stop pedaling.
10mm longer cranks are not helping.
A taller front end is maybe not helping.
~1lbs of water bottle hanging 1 inch off-center on the handlebar isn't helping.
Maybe there is such a thing as moving forward too much and i've extended leg weight out way too far, and also too wide.
I have done these modifications and will retest tomorrow:
Water bottle delete
Adjust the cranks back to the 'down' position.
Get the pedals inwards about 2mm. i have room to eliminate more material off the cranks to make that happen and eliminate the BB spindle shims.
Here's another aspect i can tackle later:
I could move the seat down almost an inch to make up for this extra height i've added by redrilling it.
It would get me closer to the cannondale geometry that sat me lower.
Now that i've raised the bike, it would help my CoG to get that seat lower.
The cannondale also had very low handlebars. So i've lowered and pulled back mine a smidge.
Will retest. Fingers crossed!
Water bottle delete
