999zip999
100 TW
I'm very happy with nord-lock washers.
Are you not using any torque arms on your bike?tkollen said:No need for any Loctite or similar. By tightening the nut the insert is also automatically tightened as well by being pressured onto the outside wall of the axle thread.
Joe Perez said:Thus, the amount to which I can torque that nut is extremely small before it skips the threads. It's not stripping the threads per se, just deforming the axle a tad (due to the cutaway) and jumping a groove.
Perhaps I didn't adequately explain the specific issue which I have.Chalo said:No, something is stripped. Threads don't open up and then just return to normal.
No, but only because the force vector is entirely different. Pedals are stressed in shear at the point where they attach to the crank. I would also not trust a welded joint here, and for the same reasons.Would you ride a bike with pedals that were glued to the cranks rather than screwed in?
probably will close shop once made enough money.
Here's a much clearer image of my own axle, so that you can see exactly what is going on:Chalo said:No, something is stripped. Threads don't open up and then just return to normal.
Hence the need for a strong epoxy to bind the collar to the axle. I don't like the fact that it will render the motor permanently closed, but I can't think of a viable alternative at the moment.Chalo said:I gotta say-- that slotted part isn't a thread per se, even though threads are cut into it. Because of the opening, it won't be able to hold normal thread retention forces, even with an insert stuck on it. When real fastener tension is applied, it will scoot out of the insert the same way it escaped your axle nut.
Well, if you have any suggestions for how to remove the torque plate which is there presently (bearing in mind that it's quite seriously affixed to the frame with DP-420), I'd be happy to listen. I have considered trying to shave it down using an angle grinder, but I can't see how I'd maintain any reasonable degree of straightness and flatness.Seems like time for a thinner torque arm (no epoxy, Gorilla Glue, or wheat paste required, just mechanical fasteners) and a credible attempt to pick up some functional threads on that axle.
Joe Perez said:Well, if you have any suggestions for how to remove the torque plate which is there presently (bearing in mind that it's quite seriously affixed to the frame with DP-420), I'd be happy to listen. I have considered trying to shave it down using an angle grinder, but I can't see how I'd maintain any reasonable degree of straightness and flatness.Seems like time for a thinner torque arm (no epoxy, Gorilla Glue, or wheat paste required, just mechanical fasteners) and a credible attempt to pick up some functional threads on that axle.
Joe Perez said:Hence the need for a strong epoxy to bind the collar to the axle. I don't like the fact that it will render the motor permanently closed, but I can't think of a viable alternative at the moment.Chalo said:I gotta say-- that slotted part isn't a thread per se, even though threads are cut into it. Because of the opening, it won't be able to hold normal thread retention forces, even with an insert stuck on it. When real fastener tension is applied, it will scoot out of the insert the same way it escaped your axle nut.
voicecoils said:Could you possibly modify the torque plate to turn it into a axle pinching type? That would hold that side of the axle in without relying so heavily on the nut.
Haha, what's with this "when" business? I'm far from ready to give up on this unit.dnmun said:when you look at a new motor
The only electric heat gun I own is a 250 watt Weller 6966, which I use for heat-shrinking small tubing. The torque plate would just laugh at that.Ypedal said:dont use a torch... a plain electric heat gun will get it hot enough imo. ( if you opt to remove them )
That's why it isn't Plan A.Ypedal said:plan C is a bad one... :lol:
I know for a fact that you are not the first to be bitten by this issue: I had the identical problem torquing down my first BMC and similarly solved it by just picking up a few more threads. I am confident this general strategy will be effective.Joe Perez said:Plan A will be to ... hope that the extra 2-3 threads' worth of engagement that this gets me will be sufficient.
No kidding.teklektik said:I know for a fact that you are not the first to be bitten by this issue: I had the identical problem torquing down my first BMC and similarly solved it by just picking up a few more threads. I am confident this general strategy will be effective.
Yeah, this bugs me about bikes in general. Being an engineer by profession and a shadetree auto mechanic of 20 years, I'm accustomed to there being a torque spec for everything. Granted, there's no good way to put a torque wrench on a nut that has a bunch of wires poking through it, but at least it would put me in the ball-park.The real failing here is that there is no max torque spec for the BMC axle nuts
