I finally got the extended battery back to my bike mounted properly. I decided to make a run to the local hill to test out the performance of the batteries.
About 6 miles into my trip up a 1500' ascend the motor cuts out. No pop, no nothing. I still got power to the controller but no throttle response what so ever.
I went through fechter controller diagnostics with the following results.
1. Power to the controller with LED lit. CA registered 33V
2. Voltage regulator works, +14VDC & +5VDC & CA is active
3. Throttle works. Sense goes from 0-4.2V
4. FETs check are all open between GND & phase while I get a -3.8M Ohms between (+) & phase
5. gate vs drain diode check ... 0.3V seems good.
I then proceeded to check the motor side. Hall sensor looks good at ~700 Ohms vs GND. GND & +12 and all the phase wires were shorted together? HUH!
Opened up the BMC motor and look what I found.
A bunch got welded together.
The culprit ... one of the phase wire with insulation completely vaporized! ... Yes Completely Vaporize!
The funny thing is I was running with 36V battery pack & 35A controller with the Cycle Analyst current limit of 25A.
So you guys with BMC expecting to run > 1000W I would highly recommended that you review your wires, especially if you're going to just shorten the stock.
The good thing through this entire ordeal is I got an intimate look in my motor & controller. Not so mystique as it used to be.
Thanks fechter & Doug for helping me through the troubleshooting process. Hopefully my controller is OK and a quick rewire (beef up to 14 or 16 AWG) would get me back on the mountain.
