Muad'dib
At last, my ebike has come together. I got turned on to ebikes a couple of months ago by an engineer friend who made an electric tricycle for his Masters degree project at UC Davis. Much to my wife's dismay, it has become a passion and I have been spending A LOT of time on this forum researching and figuring out the basic lingo of the hobby. Thanks to all who have patiently answered my newb queries. The bike below is a starter bike, I know it ain't elegant, but it works.
Battery:
My real battery pack will be 20amp hours of Headway cells, whenever they end up coming, waiting waiting along with the other group buy folks. I decided to get myself 5ah of Lipo (Turnigy, from Hobbycity.com, 3 packs of 5s1p) to play with until the Headways come. I wired the 3 packs in series for a "48v" pack of 15s1p Lipo cells.
Controller:
Infineon 48v 50amp from ecrazyman@gmail.com. Cheap, good reputation, came very quickly via UPS. As a newb, I find it hard to understand that this thing comes with absolutely zero instructions. Luckily I have this forum where everything about that controller has been explained over and over. Took my dad and I awhile to figure out that mating same colored wires does not work for any of the harnesses! After some worrying about whether there was something wrong with the motor, I found the right sequence posted on the forum:
Motor wires
Blue -> blue
Yel -> Green
Green -> Yel
Halls
Red -> Red
Blk -> Blk
Green -> Yel
Blue -> Blue
Yel -> Green
Motor:
I researched all the major hub motors and non-hub creations for a long time and decided to try the new BMC "1000w" geared motor. I live in a hilly area, so the geared motors appealed to me and I could find little if any bad stories about BMC motors in general. The gears used to be nylon which they say would wear sooner, but now that are apparently a composite material that is better.
Desired Speed:
I wanted a bike that could keep up with traffic so I was aiming for something that could do 40mph whether I actually went that fast most of the time or not. The 600w BMC is said to max out around 35mph which is close to what I wanted, but I thought that it is better to get the more powerful motor and not use it than be stuck with a slower one. I am 220lbs, so I also wondered if the 35mph figures were with 150lb guys riding or what.
Preliminary Results:
Got it running this morning and boy was it fun! The motor didn't really feel alive until I got up some speed, like 10mph or so, but then it kicked in and accelerated very quickly. Maybe this sluggishness in the low speed has more to do with the controller though. I don't think it was made with the soft-start feature that is now coming out for Infineons. It bogged down a bit on the steeper parts of the hill near where I started. On another hill where I had some space to accelerate before hitting the hill, it zoomed right up it like a car. Later today I did a speed test with my friend following behind in a car. The only straight road near my place has an ever so slight upward incline, wouldn't really notice in a car, but still on that he said I was going around 34 mph. Not too shabby.
UNFORTUNATELY, after that, the motor cut out all of a sudden. I stopped and checked everything. All wires still connected, motor cool to the touch, batteries cool to the touch, controller warm. It was warm too earlier in the day after only a minute of riding. I didn't think it could have burned, it would be hot right? But after testing everything else, I opened it up and it did indeed burn.
I'll be contacting Keywin and hopefully he will get another out to me. This controller should have been plenty up to powering this motor, so some kind of shoddy assembly I guess. I'm posting the burn pictures too. The top of the board is fine, only one spot on the bottom burned.
All in all I'm pretty disappointed that this happened.
Battery:
Controller:
Motor wires
Blue -> blue
Yel -> Green
Green -> Yel
Halls
Red -> Red
Blk -> Blk
Green -> Yel
Blue -> Blue
Yel -> Green
Motor:
Desired Speed:
