Just bought and fitted my second conversion kit. My first was a 36v 350w Mac fwd infineon controller using a Ping LiFePo 10ah that reaches 22mph on the flat. The new kit from BMS is a 36v KU123 500w Bafang BPM I 201 rpm. Unfortunately it's topping out at around 16/17mph. None of the various speed controls have been connected (speed limiter or 3 speed switch - it goes even slower when they're connected) and the motor or controller hardly get warm even after a steep climb even drawing 33 amps max!
My friend also built his second project which is a 48v KU123 500w Bafang BPM II (the new less shiny one) rwd 201 rpm as part of the same order. He can also only manage 16/17mph. He has a 48v 500w Mac rwd infineon kit that tops 27mph.
Any ideas why the performance is so poor for both kits? I've emailed Judy at BMS so hopefully will receive a reply. Is it restricted for the European market? Can I not expect much more from the 201 rpm?
If I can resolve this I'll be very happy with the kit that arrived quickly and in good order.
