1. I know it’s a 13s4p pack.
2. You stated " I'm not parsing through it all, over my head, but battery SoC is not easy, cannot be accurate from voltage."That is correct you are not parsing it all and you are the one who is getting confused.
3. You then stated " 14S ? full charge is 58.8V, ~57V would be better for longevity giving up very little range."
4. You then stated "48.3V is 3.45Vpc, pretty good conservative definition of 0% to get a decent cycle lifespan."But it isnt 0% and not the 0% lowest voltage tested which is what I was asking for.
5. You then stated "Sorry but did you confirm that yours is a 14S pack?, My point, if it is, is that at 54.4 / less than 3.9Vpc, you are very far from fully charged.
To get decent range you need a charger that gets you to at least 57V, maybe 58V."
which is wrong because you are talking about a 14s pack and not a 13s pack.
6. Then you state " And 48V **at rest** still has a fair bit of range left." contradicting the previous point at which point actual 0 is.
7. I then states this explicitly "I thinks its probably a 13s pack. Its a cyclotricity 48V frame pack, I don't think its the 16a/h one."
8. Then you state I have probably been sold a poor quality pack, which I haven't. The cells are genuine. Then you state I am not stating the vendor when I have, its cyclotricity. "Why would you not name them? Someone here may have a knowledgeable contact there."
9. You then state :"Not sure why you also discuss the specs for 14S / 52V nominal nor 10S / 36Vnom? Not relevant, if you are sure your pack is 13S."TO MAKE SURE NO-ONE GETS CONFUSED BY YOU.
10. "So no idea why you keep getting this wrong:"
> 2x2850mAh = 5700mAh per cell or 5.7Ah. There are 52 cells in a so 5.7Ah x 4 = 22.8 Amps max output.
To let motomech see the mistake in their calculation using their method. 2 is the discharge rating or 2C.
11. "Rather than relying on Samsung's rating, better to research real member testing data discussions on the various 29E iterations
https://www.google.com/search?q=site%3A ... amsung+29E
All I wanted to know is what the pack is a 13s4p at 11.4 ah. That’s it.
12. You are being pedantic, not following the full thread and making many mistakes. You even admit this yourself. If my initial calculations are wrong, that's fine , its how we learn but the only thing you are doing is not making much sense and not explaining things properly which is what you should have done in the beginning. You didn't and now here we are. You keep saying "you have no idea" and you are right, you have no idea so please stop.
