izeman
1 GW
hmmm. afaik the schottky is the 3pin to-220 like one connected to the cool sink. correct?
connected to the middle pin, but i didn't show any voltage.
fyi, takes some courage, but i just plugged and unplugged my batts in very quickly and then could adjust the voltage. no problems at all.izeman said:i don't want to connect it to the battery before checking the voltage.
Example 10S charger
Our NCM/Li Ion Chargers come with a 3 position switch to set output voltage to 42V, 41V and 38V. This enables charging to approx 100%, 90% and 50% SOC. Regularly charging to 90% SOC will help to extend cycle life. Charging to 50% is recommended for battery storage.
Example 14S charger
Our NCM/Li Ion Chargers come with a 3 position switch to set output voltage to 58.8V, 57.4V and 53.2V. This enables charging to approx 100%, 90% and 50% SOC. Regularly charging to 90% SOC will help to extend cycle life. Charging to 50% is recommended for battery storage.
Example 17S charger
Our NCM/Li Ion Chargers come with a 3 position switch to set output voltage to 71.4V, 69.7V and 64.6V. This enables charging to approx 100%, 90% and 50% SOC. Regularly charging to 90% SOC will help to extend cycle life. Charging to 50% is recommended for battery storage.
if i plug it in, the voltage of the charger shows the voltage of the battery - what else. connecting it makes the relais click, and after unplugging it, voltage starts to decline slowly. when it reaches 12v (around 30-60s) the relais opens again.GCinDC said:fyi, takes some courage, but i just plugged and unplugged my batts in very quickly and then could adjust the voltage. no problems at all.izeman said:i don't want to connect it to the battery before checking the voltage.
0V.izeman said:if i plug it in, the voltage of the charger shows the voltage of the battery - what else.
0V BEFORE you connect it. of course, as the relais is open, but when you connect it, the voltage is pulled down to a common level, which is battery's level. so when it's connected you can raise the chargers voltage as much as you like, it will not move.GCinDC said:0V.izeman said:if i plug it in, the voltage of the charger shows the voltage of the battery - what else.
if this is a reply to my post: yes. i know that. just wanted to make sure that i expect no voltage to be there because of the relay. i like to state the obvious in my posts to avoid further replies stating that and this way prolonging the root cause findingdnmun said:the charger has a relay on the output. it is totally normal for there to be no voltage on the output for the large chargers if there is no battery connected.
izeman said:can't make that thing turn on for setting the voltage. i don't want to connect it to the battery before checking the voltage. i followed doc's thread on how to turn the relais on, but i can't remove the board to connect the resistor, as the board is glued to the case. what pins/solder pads on the upper side of the board have to be connected to turn on the 900/1000w type?
help is much appreciated.
GCinDC said:thanks for the links to those other chargers, chroot. unfortunately, they're lower voltage.![]()
if folks know of other working high voltage chargers/sources, please post a link.
i can't find the emc-1000 label written on the board. but it's got the very same daughterboard with the blue resistors on it, and it looks exactly the same as all emc-1000 pictures i've seen.dnmun said:do you have the charger labeled EMC-1000 or is it a different type?
yes. i did that. i already found a second non working charger (which board was not glued to the the case) and was able to follow traces. measuring at the choke and GND was the first thing i tried. the choke goes directly to the middle pin of the shottky. as said: if there is no battery connected, and the relais is open, then it shows -0.5V.dnmun said:you can measure the voltage in front of the output relay to find the voltage when there is no battery connected. i thought i explained that you would measure at the spot where the choke (the big round toroid wound donut) is soldered to the pcb. that is the output of the schottky diodes.
not checked the fuse, but it should be ok, as there are some ac voltages present on the board, and the red and green led are lit. is mt assumption wrong? i would check directly, but am in the office right know so i can'tdnmun said:so no current from the schottky means the front end is not pushing current out of the back.
the ground lead, the - spot where the blue wire connects, is connected to the other side of the transformer and the shunt is part of that ground wire.
so the diode can be open circuit or there is not any switching of the npn transistors in the front end to make current flow out of the transformer.
that would give you no voltage at the choke. that is what goes through the relay.
you have checked the fuse? under the plug?
300v dc between collector and emitter of the other n channel bipolar transistor. i guess this was the one you were referring to.dnmun said:if the leds are lit your fuse is ok. just checking. you can measure the hi voltage on the front end? it should be 340V from the top of one collector to the emitter of the other one.
base voltage is about 50V. that is where the switch is placed when there is a switch on the charger. to turn off the base current in the transistor.
'Has anyone seen this' was referring to the bent pins. Not the transistor. The local electronics's shop sells them for $20+.dnmun said:GT50J325 is an insulated gate bipolar transistor, IGBT. i got them for $4 each from utsource.com since they are $13 from mouser.
