cal3thousand said:
Madin88,
What did you end up doing for the charger situation? I'm interested to know.
izeman has lent me one of his EMC-900 chargers with super nice display until i have a own one again.
I have ordered the kingpan KP-C 1200W from evassemble about 10 days ago:
http://www.evassemble.com/index.php?main_page=product_info&cPath=3&products_id=9
Im not very happy with this shop. still not have got a delivery confirmation (maybe set the charger to my required 91V does take that much time). the email response is very slow.
including shipping it costs me about 300$ (220€). I hope it will pass the customs so i have not to pay additional 20% duty costs.
I decided to go this way because the meanwells do not cut off at the end of charge. this means they will hold the battery forever to the set voltage.
the kingpan does have a relais and they will break the connection automatically.
As i could see, the Meanwell CLG-150 from your link also does have a constant current limiting function (like the popular Meanwell HLG series) so i think it should work well without Fechters limiter board :wink:
You can connect them in series and set the volts to your needs. If you do so, you have to add some diodes in the circuit to protect the power supplies from too much volts.
For example: you have 60V battery and two supplies set to each 30V. If one supply sees the 60V it will blow up.
izeman, do you think you can repair my EMC-1000 or do you have the parts for the repair?
sorry for the broken screw left in the case. in future i will throw them away and cut some M3 threds in there like you always do
