dnmun said:the fuse is under the plastic cap where they have the emblem of a fuse. you could put a rocker switch underneath for on/off too.
yes it must be under this cap, but something is broken off there
izeman said:maddin you should not compare it to the one i gave to you.normally the board is not screwed to the case. this was something i did to make it stronger and fail proof.
i know, but i want to mention how cheap these chargers are built. nothing compared to european or us standards.
As i told you the charger you lent me is off his "electronic head". It very often sporadic turns to fully charged (green led) and stops charging. Sometimes it doesn't cut off which is very dangerous without bms (it simply charges further and further if it exceeds the set voltage without reducing current). Glad i was in the room and took a look every few minutes. It was already at 93V the first time i noticed this strage behaviour
