izeman
1 GW
I have now experienced another issue. Charging works fine with both chargers. The fan is off until the FETs have some 50oC. Then the fan starts, runs for some minutes and then the charger turns off, turning the charging led from red to green.
Battery is not fully charged though. I set the no-load voltage to 87.6v for 24s. But charging stops way lower. It seems timer based and not voltage based. If I pull the plug and start all over again I can charge some minutes more.
