groinedvault
I am rebuilding a 5S2P pack using 10 3Ah 30A VTC6 Murata cells. The original cells had only 1.3Ah capacity.
I connected the original bms, charged the pack, but the grinder won't run although I read 20.44V across the terminals. I think the original bms is no longer suitable as the new 6Ah capacity and the new continuous current rating of the cells are much higher.
But my knowledge is limited and would appreciate any help to get the pack working. Do i need a new bms? Am i right to think that bms should be rated 60A because of the 2P connection. There are lots of 30A boards on AliExpress but not 60A. Or am I wrong with the 60A rating that I am proposing. The size of the board should be 85mm x 63mm.....standard i guess for the 5S2P configuration. Can someone point me to a suitable bms. Any comment is appreciated. This is my first time on this forum
, so apologies if this is not the right way or place to do this.
