Hi,
I'm building a 10S4P pack for an escooter, and im going to use the BMS in the photo:
The BMS low voltage cutoff is rated at 2.8v, which sounds too low to me, how do I make the LVC higher (do i need to add another component)? And what is the recommended LVC?
I will mention that this pack will be connected in parallel to the original one, that already have BMS and a cutoff of around 3.3v i believe.
Thanks
Thanks
