BMS with charge profiles built in for Blind DC
Doomsdayprep
10 µW
Hello all fellow fans and like minded people.
Im in the quest of searching for a BMS that has a Charge profile and Max voltage cut off when the back is full ?
Please could i kindly get some information to where i can find these, ideally i want to use a set of 18650 cells as a pack and want to be able to supply ppower at night to my DC loads but be able to charge the Lithium pack during the day .
Please let me know what solutions there might be as i have searched high and low.
I dont want to use a lithium smart charger as in some cases this pack will be connected to a basic solar panel for charging .
the charge profile is in order to use the BMS with different chemistries?
Usually the BMS is installed for a specific number of series and kind of chemistry (max voltage cut, balancing voltage, low voltage cut) and then you use for example a Solar controller with configurable charging voltage in order to charge the pack and also to discharge.
Indeed all the BMS boards has a max voltage cuttoff.
If I missed something please clarify!
What are the number of serials and parallels on the pack you want to install the BMS board?
hi there i have managed to locate a smart charger for the lifepo4 systems i am designing and this will go along way in ensuring the cells are charged correctly .
Thank you for your input once again it has been most valuable .
Smart charger ? What makes it so smart ?
What bms will you be using ? I always put a set of sense wires for ez checking or balance. Yes with a bms. Curious minds need to know.
