ridgerunner
10 µW
- Joined
- Mar 17, 2020
- Messages
- 5
Good afternoon...
I have some basic questions that I am hoping this forum can answer. I would like to get a 5S3P Li-Ion battery with a BMS. I have multiple applications: A) 5S3P (x3) in series for a 15S3P configuration B) 5S3P (x3) in parallel for a 5S9P configuration.....I am trying to decide whether to do a 15S BMS that is over-sized both on the voltage and current to support the requirements of the parallel configuration OR whether to embed each 5S3P with a 5S BMS. So now to my questions:
1. If I have three 5S BMS in parallel will they conflict with each other? My understanding is parallel cells balance themselves out and the BMS is there to support the series cells, so my inclination is to think that the three in parallel will work??
2. If I go with a 15S can I hook 3x 5S3P at the bottom end of the 15S BMS and will it work (assuming of course it has been chosen to support the 9 parallel cells current charging / discharging requirements?
3. Final question...Would I be able to build the battery packs up WITHOUT BMS and then use 1x 5S BMS external to the packs to balance 5S3P (x3) in parallel if I sized it appropriately for the current for the 9 parallel cells?
Sorry if these are simple questions as I'm just getting my feet wet here in this.
Sincerely,
Steve
Sincerely,
Steve
