hydro-one
another case of industrial espionage. this is becoming common in the battery manufacturing sphere. (remember a123)
dnmun said:i don't think they had low standards at A123. from what i read, during assembly of the pouches, there was a registration error when the separator was mounted in between the electrodes that was significant enuff that there was risk of shorting between the electrodes. there are others who may know more.
it was not from negligence or poor standards, it was just poor manufacturing process control at a critical step. i never did learn how the misalignment could be caused. perhaps there was a failure of the equipment to place the separator exactly or it could have had a built in offset invisible to the equipment controls.
dnmun said:i also wondered why they could not have some big air vent that opens directly to the exterior of the plane on this battery box. if it overheats just exhaust so much air through the box it would carry the heat away and then have water sprayer inside the box to cool it along with the air flow to suck all the moisture out of the electrical bay there.
Martin A said:From The Guardian newspaper in the UK
......But because the causes of the problems with the 787 batteries remain unclear,.
http://www.news.com.au/business/breaking-news/boeing-seeks-temporary-dreamliner-fix/story-e6frfkur-1226580806306Boeing may encase the battery cells in a titanium or steel box fitted with a high pressure vent to contain any fire that erupts in flight.
What's wrong with that? Sounds like one of our Lipo ammo box setups. Fill the top space with marshmallows that will expand and melt under heat and smother the flames. Also makes a tasty snack for accident investigators.Hillhater said:I cannot believe the latest rumor on this subject ..![]()
fechter said:I still think it's the French BMS...
The latest application of Securaplane's battery charger is for charging and managing the Boeing 787 main ship lithium battery used for APU start and electrical system support.
Associated Press
TOKYO — A probe into the overheating of a lithium ion battery in an All Nippon Airways Boeing 787 found it was improperly wired, Japan's Transport Ministry said Wednesday.
The Transport Safety Board said in a report that the battery of the aircraft's auxiliary power unit was incorrectly connected to the main battery that overheated, although a protective valve would have prevented power from the APU from doing damage.
Flickering of the plane's tail and wing lights after it landed and the fact the main battery was switched off led the investigators to conclude there was an abnormal current traveling from the APU due to miswiring.
The agency said that more analysis was needed to determine what caused the main battery to overheat and emit the smoke that prompted the Jan. 16 emergency landing of the ANA domestic flight and the worldwide grounding of Boeing 787 jets. They said they are consulting Boeing about the issue.
The Federal Aviation Administration and aviation authorities in other countries grounded 787 fleets because of the ANA incident which followed a battery fire earlier in January in a 787 parked in Boston.
The 787, dubbed the Dreamliner by Boeing, is the first airliner to make extensive use of lithium ion batteries, which are lighter weight, charge faster and contain more energy than conventional batteries similar in size. However, the batteries also are more prone to overheating and catching fire.
(Reuters) - Boeing Co (BA.N) has found a way to fix battery problems on its grounded 787 Dreamliner jets that involves increasing the space between the lithium ion battery cells, a source familiar with the U.S. company's plans told Reuters.
"The gaps between cells will be bigger. I think that's why there was overheating," said the source, who declined to be identified because the plans are private.
A spokeswoman for the U.S. National Transportation Safety Board declined comment on the Reuters report or any Boeing plan to return the 787s to the air.
"The decisions to return the airplane to flight will be made by the FAA and only after Boeing has demonstrated to them that the solution is adequate," Kelly Nantel said. "We continue to investigate the cause of the short circuiting."
A spokeswoman from the U.S. Federal Aviation Administration declined to comment. Boeing declined comment on details of any battery fix it may be considering.
The 50 Dreamliners in commercial service were grounded worldwide last month after a series of battery-related incidents including a fire on board a parked plane in the United States and an in-flight problem on another jet in Japan. Until the Dreamliner is cleared to fly again, Boeing will be starved of delivery payments.
The logical solution for Boeing would be to install ceramic plates between each cell and add a vent to the battery box, Kiyoshi Kanamura, a professor at Tokyo Metropolitan University who has conducted research with several Japanese battery makers, told Reuters on Tuesday.
Earlier on Wednesday, the chairman of state-run Air India AIN.UL said Boeing is hopeful of getting the Dreamliner back in service by early April.
"They said that these planes should start flying again from early April. They can't be sure but they are hopeful," Rohit Nandan said.
Air India has six Dreamliners and has ordered 21 more. The question of the airline seeking compensation from Boeing for the jet's glitches would be taken up once the aircraft are flying again, Nandan said.
"We have been in close communication with our customers since this issue arose," a Boeing spokesman in Seattle said, regarding the issue of compensation. "The details of our conversations with customers are confidential."
The Boeing spokesman declined to address the details of the battery fix, but said it was making progress.
"Boeing has teams of hundreds of engineering and technical experts who are working around the clock with the sole focus of resolving the issue and returning the 787 fleet to flight status," he said. "Everyone is working to get to the answer as quickly as possible and good progress is being made."
On February 7, in its most recent official update on the Dreamliner, the NTSB said it had a "long road ahead" in its investigation of the lithium ion batteries.
Spokesmen for Japan's All Nippon Airways Co Ltd (ANA) (9202.T), which has the biggest fleet of Dreamliners, and Japan Airlines Co Ltd (JAL) (9201.T) said they were unaware of the suggested April schedule.
ANA and JAL have been most affected because they own around half of the lightweight, fuel-efficient jetliners in operation as a strategic move to win market share from their U.S. and European rivals.
Boeing shares rose on 1.3 percent on Wednesday, to $75.64 on the New York Stock Exchange.
