stiffi
How about this guy?
The max output is 41.6 volts, http://www.all-battery.com/TenergyBatteryCharger01222.aspx
stiffi said:The max output is 41.6 volts, http://www.all-battery.com/TenergyBatteryCharger01222.aspx
stiffi said:So, nobody can recommend a good (yet smaller) charger for these packs? I'm having a hard time finding any 36 volt Li-Iion chargers, really
I'm thinking more and more about just sticking with the Bosch charger.
I would appreciate it, if anyone could point me to a particular replacement, however
thanks
I actually have read the entire thread, several times. I just don't always know what I'm looking at.Russell said:So much of what you've been asking has been covered extensively earlier in the thread :?
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=7569&start=105#p151224
-R
pwbset said:stiffi said:The max output is 41.6 volts, http://www.all-battery.com/TenergyBatteryCharger01222.aspx
Sure, that works. Really depends on how much you care about cycle life. 41.6v is still .6v/cell over the Sony recommended max charge of 4.1v/cell for the VTs. If Bosch is only charging to 40.5v they can probably claim 1,000+ cycles pretty easy. I'm charging my VTs to 4.2v/cell because that's the ecitypower charger I have and will be happy if I get 2-300 cycles out of them. That's still 2-3 seasons of riding for me.. last year I did ~115 cycles. Some people really care about having 2,000+ charge cycles... why I'll never know, but they do. I don't think it's justified unless you've invested in an $$$$ eCar that's gotta last forever. By the time you actually use your 2,000 cycles on a little ebike I'll be riding around on antimatter. :wink: Even 2x/day full DOD that's still like 2.75 years riding every single day... I doubt many people do that.
So yeah, really just depends.
stiffi said:they will run constant current/constant voltage.
stiffi said:Is there any fear of explosion leaving them plugged in after they are charged?
stiffi said:You mentioned you have the ecitypower charger. Do you watch the charging process closely, and pull the packs off as soon as they are charged? Or can you let it sit a while? I was told by the ecity power folks that their chargers are not smart, they will run constant current/constant voltage.
thanks.
stiffi said:I actually have read the entire thread, several times. I just don't always know what I'm looking at.I'm not the most technically inclined.
So, if you would indulge me again...
Are people using a BMS in their packs, if they are using the Bosch charger? I was all set to purchase an ecity charger, and then the rep said I should get a BMS. then I panicked. I know 1 pack with the Bosch charger doesn't require a BMS, but do I need one with multiple packs chained together?
D-Man said:I'd use the Bosch charger! Good luck.![]()
Ok Einstein.pwbset said:D-Man said:I'd use the Bosch charger! Good luck.![]()
Any old CCCV charger will work provided you respect the cells specs. Sony states 4.1v/cell for VT cells... this is a fact. Bosch chargers take them to 4.05v/cell presumably to lengthen cycle life a tiny bit. That's fine, but there isn't any reason you can't take them to 4.2v/cell and get an extra .2-.3ah at the cost of cycle life... it's not like they will explode or anything... I've had (accidentally) VT cells to 4.35v+ without issue. They are tolerant cells to say the least. Just saying.. every penny saved counts these days so why not save $100 on a charger if it'll get the job done?
D-Man said:Ok Einstein.
D-Man said:No one has yet documented and measured the exact ah gain of using a higher voltage charger. There might not be anything measureable. You think the engineers that made the Bosch charger to go with Bosch packs are fools and don't know jack about batteries? Or I guess people in here think endless-sphere is smarter then Bosch engineers and would rather buy offbrand. I'd use the Bosch charger! Good luck.![]()
stiffi said:Hey pwbset, what kind of connector is on your ecitypower charger?
so which wires did you decipher to be + Red and Black - ?pwbset said:stiffi said:Hey pwbset, what kind of connector is on your ecitypower charger?
I don't know if they are all the same, but mine came with a 3-prong "AC" style plug. I used a multimeter to find + and -, ignored the "ground" and added anderson connectors so it plugs right into my battery pack. As mentioned on the thread linked below you could just nix the entire end plug they give you and just attach andersons diretly to the output of it.. depends on how you hooked up your packs I suppose. I use andersons for everything.. very easy to work with.
http://endless-sphere.com/forums/viewtopic.php?f=14&t=9054&start=105#p153529
I'm digging this charger... puts out about 350 watts so charges my pack quickly and despite 120+ degress in my garage in the afternoon it's happily charging away on it's ~20th cycle... so far so good... :wink:
stiffi said:so which wires did you decipher to be + Red and Black - ?
