scrambler
Actually, the best way to eliminate any influence of the rear sprocket size would be to add a fixed wheel on the frame as in the schematic below. The wheel would be attached at the back of the swing arm, so basically invisible.
Now, In order to see if we could predict the feasibility before actually getting a sensor and trying it, I made the schematic below to calculate the pressure on the wheel attached to the sensor, based on the pedal pressure, the bike dimensions and the deviation angle created by the sensor positioning.
Note: There is as small approximation done carrying the opposite chain tension forces in a single point, but the error induced should be negligible.
Assuming my rusted physics are correct
), If I can find the value of the force applied to the sensor axle location that corresponds to the sensor output range, we can predict if that configuration can work with that sensor as is.
ID Bike (Sensors (idbike.com) ) mentions a usable TMM4 sensor range of 40Nm in high sensitivity mode and 100Nm in medium sensitivity mode, but without knowing how they measure that, it does not give us the axial force that correspond to these torques at the sensor level.
I have sent an inquiry to ID Bike and Tranzx, we will see if they respond...
