Hi all
I'm new to this forum and to ebikes, so please bear with me if I get any of the terminology wrong.
OK, I bought an ebike kit and triangle battery from the same eBay supplier after confirming that all components were 100% compatible with each other. The kit consisted of:-
KT-LCD3 display
1500W rear motor in a 26"*4" double rimmed fat bike wheel
48V 1500W 45A controller
Half twist grip throttle
Replacement brake levers
Pedelec sensor
48V 20ah battery
I then got a local bike shop to do the conversion using a 17" fat bike.
The guys from the shop were a father and son team from the UK and did a fantastic job.
Anyway, the job was finished at about 5pm and I rode it for about 35km and everything was perfect.
The next morning I took the bike out again. I was using the minimum assist level and the wattage was approximately 250W from the display.
After about 10 km, the power seemed to momentarily disappear and then resume again. This happened a few times.
Up until now, the ride was on relatively flat ground but after about 14km I had to go up quite a steep hill.
I changed the assist level to 3, but the bike didn't really seem to perform well, so I changed it to 5 and was getting an indicated 2Kw to the motor, but it really didn't feel like anywhere near that.
At the top of the hill I changed back to level 1 at which point I lost all power.
The display was illuminated, but the battery icon was showing blank. At this point I had well over 50 volts in the battery.
I checked for obvious faults but couldn't find anything. The motor was warm, but not hot, but the controller was absolutely boiling.
Hot as in too hot to touch.
I contacted the supplier who suggested changing the C5 setting to 5, which I have done but this didn't restore any kind of functionality. After a bit of a discussion with the supplier, he has agreed to send out a new controller.
I now have a few queries which I hope someone can help me out with.
It seems, according to Google, that these sine wave controllers run fairly cool. In fact, I can't find any reference to one overheating. The controller is housed in a bag to the rear of the bike, visible in the photo, instead of the supplied bag. I live in Thailand, which is pretty hot, but nowhere near hot enough to adversely effect the controller temperature I would have thought. It was pulling maximum power for less than a minute, but unfortunately I have no idea of what temperature the controller was at prior to the hill. Anyway, does this sound like a bad controller or is excessive heat a feature that I should be aware of?
Secondly, I was sort of hoping that the controller might have some sort of thermal cutout that might have operated, but as it's still broken and in the absence of a reset switch, this seems unlikely. So, my question is, is there any kind of possibility that I can repair or recover this controller? There's no such thing as an ebike shop even remotely close to me.
Thirdly, after endurance testing and making some gearing changes to the bike, I was hoping to use it for touring. I now am concerned about reliability. Generally, are these controllers reliable and have I just been unlucky? Is there a better controller that I should be looking at?
Apologies for the length of this post and the fact that it's been a bit of a brain dump. I'm a little frustrated that an expensive project has failed so quickly.
Regards
Mike
Edit: just to add, I did not at any time have any error conditions displayed via the screen.
Photos attached
KT-LCD3 display
Pedelec sensor
48V 20ah battery
Regards
Mike
Photos attached
