Supersleeper
- Joined
- Mar 20, 2013
- Messages
- 48
Hi Folks,
I've had my starter motor replaced, and asked to keep the original part. I found that the only thing wrong with the motor was the brushes wore out due to oil getting inside. I was going to drop by the parts store and get a new set of brushes for it. I don't have a lot of options with it's current configuration as the solenoid housing limits access to the drive shaft, and if I remove the housing, there's no bearings to hold the motor shaft at the front. Also looks like there's no true bearings in it, only bushings. The drive shaft is easily removable.
So this begs the question as to what it would be fun/easy to do with as a project? Maybe the answer is to build a new housing with bearings and ventilation? Maybe just go buy a fly-wheel from a junk yard and bolt the stock housing to a frame and play around with wind power generation? Industrial grade shredder? Maybe make a baseball or softball launcher for my kids?
