yelnatsch517
New here
- Joined
- Jun 14, 2013
- Messages
- 16
Venus said:I just wanted to add my board to the list.
It uses an SK3 6354 260 KV motor, 6S 6000mah Lipo and 150 A Hobby wing ESC. I just did a 16 km ride and arrived home with an average cell voltage of 3.75v. I was cruising relatively slowly, maybe 20 kmph, but carving the entire time. So I would estimate I could get 20 km if I drive efficiently and not go too low to hurt the battery.
With the 76 mm wheels it has a calculated max speed of about 45kmph, I have taken it up to 38. I would estimate it will do 40-42 under ideal conditions. I am a wimpy skater and prefer to cruise at 25 or so. Final weight is 6kg.
It is much even better than I expected it would be. The entire time, I have to fight the ridiculous EV grin.
There is very little I would do differently. Perhaps the new 12 tooth pinion gear to limit top speed some more. I wouldn't buy the hard case 2s batteries next time. The wires are bulky with the required 90 degree input angles. 5s would also help limit top speed and make my cruise throttle setting easier. A slightly lower KV motor would be another way. For me a top speed of 35 would be ideal. I have found from my electric bikes it is much more relaxing to cruise at full throttle. I am quite sure I could get away with 3/8 spacers instead of 1/2.
I would like to thank Richard for putting together such a nice kit. Everybody should own one of these!
That's awesome, that sounds like what I want to do. I wanted a portable <15lb board capable of more than 15miles.
What gear ratio are you using? Are you using the Alien pulley and mount kit or did you make them yourself?
Also, what remote are you using?
beetbocks said:Great Venus - that's looking good .. Yes the lower gearing is needed for the 270 kv as you say .
That's why I'm producing the new 2 peice hub , so I can make larger pulleys wheels available without the cost going up too much . As a 1 peice means machining from larger blank thus meaning more machining and higher cost for the blank in the first place .
I hope in the future to offer a range of gearing solutions for different speeds/ hill climbing/ wheel/ motor size etc etc
Keeping the larger pulley the same while changing the number of teeth on the smaller pulley seems like the best option, after playing around with my excel sheet.
Lower KV motors definitely need a lower gear ratio for two reason. 1.) To achieve higher speeds and 2.) More teeth in mesh for the timing belt.
The second is extremely vital as lower KV motors usually mean higher torque. With higher torque, more teeth are needed in the mesh to prevent belt slippage.
Also, I've been trying to think of a way to adjust belt tension and I believe using some mechanism involving a socket cap screw would be best.
I've heard that timing belts tend to stretch a bit after initial usage so it's vital people can tighten the belts after a few miles of use. What do you think?
