beetbocks said:
I must admit everybody seems to want a boosted board set up but the diagonal drive works perfectly for weight distribution around the deck .
We have 3 d printer at work but to print the battery box which is 370mm long is very expensive ..
My temporary battery and ESC box would have cost less than $10 to print.
I understand people wanting a dual motor setup if they've ridden one of the older electric skateboards that didn't use normal skate trucks - they are prone to some annoying torque steer but I find with the Calibers I get none or if I do it's so negligible it isn't noticeable - I run the trucks pretty loose too. Presumably the Holeys would be similar the Calibers.
So far dual motors seems like a way to generate more drag when freewheeling, more weight, higher power consumption and in turn less range - two motors should have less efficiency but it depends on load and motor design presumably. Boosted claims 10km range and ability to climb 15% grade with 5.5-6.8kg board - I get 15km, climb 20% on my regular ride without stalling (without carrying speed into the climb) and my whole board weighs 5.75kg (12.6 pounds) - and we have the same top speed. One motor, budget ESC, Beetbocks hub, my own prototype mount and a heavier board (Arbor Pintail) than the Boosted.
So I'm saying why bother with two motors.
