dontsendbubbamail
- Joined
- May 28, 2008
- Messages
- 718
I have gone as fast as I want to go with a trailer pushing me, so it is time to build a bike. The bike, being a full suspension , needs a custom rack which I am fabing out of 1/2 inch tubing. It will be using left side drive. The hub, left hand freewheel and 56 tooth sprocket are for an ICE bike conversion. I am not sure if I will use the hub because it is steel. You can buy just the left hand freewheel and a sprocket if you want.
The last picture is how I plan to mount the motor and two jack shafts. I want to make this water proof by creating a custom cover. Wire cages will be around the chains to prevent the cover from getting snagged. The cages will also form a plenum for cooling air to the motor.
Steel Hub http://www.bicycle-engines.com/freewheel-sprocket-axle-wbrake-p-297.html
This one for $50 looks a little nicer http://www.evdeals.com/images/NewHub.JPG
Bubba
Bubba
