hillzofvalp
Hi, guys. A while back I posted a welder project with 3 .3F Spraque powerlytic caps. I gave up after a bug in my circuit. The good news is I reconstructed the welder and got it working.
Here is the good: I can blow holes in 5mil nickel on A123 26650s, dual pulse is working, and SOMETIMES I get a good weld.
The bad: when I have a good weld, the battery sticks to the copper electrodes, often leaving a smidgen of copper on the nickel. Most of the time the weld blows out and pops, leaving a little splatter/crater of nickel and blackness.. I can't find a good setting. I have been trying 300-600microsecond first pulses, 30-90millisecond pulse width, and 600-1200 Microsecond pulses. This is all at initial voltage of 15V (ending as low as 8-9V).
My theory is it has something to do with electrode contact. My electrodes are reworked sunstone double sided electrodes spaced at around .14 C-C and .065" in diameter. I file them even, weld, then one or the other wears faster (I understand that is common.
Any advice?
Update: after an hour of tinkering, I found that the positive needs to be like .005-.015" longer than the negative. I also made the structure more rigid for more consistent weld pressure. I also have it tuned in currently to 230microseconds first pulse, 20milliseconds width, and 1280microseconds second pulse. This is all at about 13.4V (using 4S A123 pack for instant cap recharges). Better results, but the welds aren't quite strong enough. I may try a bigger power supply to auto charge to 15V or maybe try a smaller initial pulse.
Any advice?
