Jonathan in Hiram
- Joined
- Oct 6, 2009
- Messages
- 446
Of course it seems that practically everything I do on an ebike is an iterative process but usually not quite as fast as it happened this time.
I spent my spare time last week building this battery box for my Long Distance Long Wheelbase bent project, got it finished to the point I could install all the electronics and put it in the bike and go for a test ride before I fabricated the removable side cover on the right side. After I looked at it for about a day semi installed on the bike I decided I could do better both in terms of design aesthetics and fabrication technique, not trying to make fine furniture since I'm going to paint it all anyway but I didn't like the slightly sloppy and untidy way the batteries (12s12p 18650) had to mount in the box.
I built that box by measuring and cutting the pieces and then gluing it up in place in the bike so that everything would be exactly the right angles and so forth and it was a real pain to do it, took me a long time.
This last weekend I started over on the box, this time I used a technique I've seen granite countertop installers use, they don't measure so much as they make a pattern out of thin strips of wood laid exactly where the outside edges of the countertop need to be and glue them together, usually with a hot melt glue gun. Each piece of granite gets its own pattern, then they take the patterns back to the fabrication shop and lay them on the slab of granite and transfer the dimension directly by tracing around it onto the granite.
Here's a picture of my finished pattern, the vertical piece in the middle is just to add stiffness to the long spans at top and bottom, I used superglue instead of hot melt and just let it sit for five minutes undisturbed.
Marking a strip for the angle to cut on the end, the strip is laying on top of the bottom tube for most of its length and I'm marking with a carpenter's pencil against the rear tube.
Clamping the next strip with the angle also cut on its lower end, the superglue tube is at the ready. You go around the entire perimeter of space you wish to fill with the box the same way, cutting and fitting a piece and then clamping and gluing it in place, you can hold the strips to the tubes with masking tape or vinyl electrical tape, electrical tape is nice because you can put a bit of stretch on it and hold things fairly tightly, you can see the electrical tape I used on this strip at the far right of the picture.
I did run into one minor problem I hadn't anticipated when doing the layout, the cable clamp bolt for the front derailleur would interfere by about 1/8" with the very front pointy portion of my box, I bent the arm a bit and ground a bit more off the end of the bolt and also thinned the nut a bit too and managed to get enough clearance without doing anything drastic.
And here is the finished perimeter of the box jigged into place after I built it exactly to the pattern, it fit the hole perfectly with no adjustments required. This time the removable panel is going to be on the left side and I have the right panel already cut and in place, the glue is drying as I type this. Using this technique with the wood strips made it about 70% faster and 100% better fit job and aesthetic design than what I did the first time.
The best part about having heavy batteries down low and forward in the bike is that it actually handles better now than it did as a bare bike, feels more solid and stable on the road and I'm more confident of the grip on the front tire.
