whereswally606
I thought I would need to good advice on how best to do this.
My friend Tim has a Long range Citroen Berlingo Converted from original Nicads to Lithium.
His charger at the moment is good for 10amps but to completely charge the pack takes days.
We would like to build a charger which can do 25 to 30 amps.
at the moment we have 10 to 15 hp esp113 server supplies, ready to be modded.
I have already built one fecther limiter board so i know how to do that and set it up. (for this project we may need two and two meanwell 24v 30amps for the compliance)
the other idea we had was to reuse the old Nicad charger which sits dormant in the car and adjust it to do the job of the meanwells. Wondering whether this would be ok?
Other issue is using diodes. Talking to Peter Perkins a while back he said it would be a good idea to have diodes top and bottom at twice the voltage and capable of the amps
the other thing i read from richard fecthers thread was that diode between supplies is a good idea to prevent the stack driving a charger backward if one were to fail.
Question is what size diodes do i need between the psus (the esp 113 ie running 12v 30 amps)?
Thanks for your help and I will do some pictures of the build when we have some.
