Hello there. I am new to these forums and battery making. I hoped some of you kind folks would like to drop me some advice on making my first lipo battery. I already know sufficient (including which BMS to use, etc) but just need a few clarifications.
I am making a 40ah battery for my 60v 3000w scooter. I haven't measured the current of my motor yet, but it's safe to assume that it peaks at 50amp and constantly draws probably around 30amps-40amps max. I am using li-po batteries and my layout will be 16S and around 8P-18P. (depending on battery mA)
Q1) If I have for example 14x300mA batteries in parallel (16 in S to make up 60 volt): then the 40amp current gets divided between the 14 of them. Which means that 2.8 amps is drawn from each battery. Is that correct?
Q2) So if each battery is discharged at 2.8amps per second: Then it means that 3000mA batteries with low discharge-rate, like 1C or 2C, should be sufficient for my purposes. Is that right? No need to go 15C?
Thank you very much for clarifying.
