auraslip
- Joined
- Mar 5, 2010
- Messages
- 3,535
In this thread I will document my latest high powered ebike build. This should take a few months as my time and funding allows.
Goals:
30 mile range at 30 to 40 mph.
50 mph top speed
Water proof/theft proof design
Integrated charger
Professional quality looks!
Frame: 23" specialized hardrock disc - the only components I'll keep stock is the drive train.
This frame has a massive triangle with room for a massive battery pack. Unfortunately, it is also REALLY tall so I'll need to run 20" wheels as well as run a shorter stem to bring the handle bars closer to me.
Another problem is that the frame is curved which should make it a bit harder to make a wooden battery box. Instead of the typical 3 pieces of 1/2" wood planks I may need to use multiple cuts of wood. I'd like to be able to plan this all out in sketchup, but I'm not sure how to accurately import a drawing of the frame.
Another issue is what sort of wood to use? In the past I've used whatever was cheapest. Is there anything better than what the local Lowes carries? Perhaps 1/2" or 3/8? wood? 1/4" is too small to drill in to for mounting.
EDIT: I ditched the hard rock and went with this frame
Goals:
50 mph top speed
Integrated charger
