Eidel
Hi!
I've been looking on Ebay for cheap parts to convert my mtb into an ebike and have found a motor, controller and battery, but I am not sure if these components will work together, so I greatly appreciate if someone with more experience could enlighten me
I have the following demands on my setup:
Desired max speed: 25 kph (15.5 mph) with 250W controller, 35 km/h (22 mph) with 500W controller
Desired max range: 40 km (25 miles)
Wheel size: 26"
Breaks: Unsure
Rider weight: 70 kg (154 lbs)
Terrain: Mostly flat, some hills here and there
Budget: around $600
The parts I'm interested is the following:
36V 500W Front wheel hub motor
36V 20AH LiFePO4 with charger and BMS
36V 250W Controller
I've chosen a 250W controller since it is the maximum power I can give the motor legally (EU-law). However, I thought it would be nice to buy a 500W motor if I in the future want to register the bike as an electric moped (if thats even possible), then I can just buy a new controller with 500W throughput. I also read that it is more healthy for the motor to not use 100% of its capacity.
Regarding the hub motor, I think it is very nice to just buy the motor and not a wheel with an already installed motor, because I want to learn how I can install motors in wheels and be able to build customized ebikes. I am however unsure how I will deal with the spokes since I probably will have to buy new ones to fit my 28" wheel.
Are these components okay? What I'm most worried about is how to connect the motor with the controller, it seems like the power cable is extremely thin. Will it really be able to handle almost 7A at full power? (250W = 36V * 6.9A).
I am not looking for the best products available, but also don't want these components to break after 6 months of use (even though I want it as cheap as possible :wink. Btw, I am aware that I need a throttle and brakes, I just haven't researched that area yet.
-- Eidel
Wheel size: 26"
Breaks: Unsure
Budget: around $600
36V 250W Controller
-- Eidel
