Lol, I think I would prefer a horse wagon! If only there were viable 'oregon trails' still left in America (Before widespread private property ownership and subsequent fencing/trespassing laws ), I'd probably try it. Just to have to remember not drinking the water, or I might get cholera, lol.
Just inspected the spark plugs. Looked good. Compression test results are the following.
Cylinder # = (psi)
(Looking from the front of the vehicle)
Right side
1=155
3=130
5=120
7=140
Left side
2=145
4=148
6=125
8=150
Family friend mechanic came over and looked it over. He thinks main/rod bearings are shot, needs replacement. Also saw the oil dripping on the right side of the engine ontop of the exhaust valve, he seems to think it needs more investigation to find the source of the leak. (He first suspected the valve cover gasket needed replacement, but now he's thinking it needs more investigation.)
Engine with 5 quarts of oil added to it is now idling, but it has a rough/squeaking running sound to it. The mechanic friend thinks it's the main/rod bearings ("sounds low in the engine"). Running dry without oil he suspects might've caused heat/friction problems with the bearings, and he recommended immediate replacement.
Todo: Inspect leak and identify/fix it. If the engine can't be sealed up, there's no point in repairing the rest of it.
Cylinder # = (psi)
Right side
1=155
3=130
5=120
7=140
Left side
2=145
4=148
6=125
8=150
