Hi,
This is my first time here. I just put an electric conversion kit on my bike last week and love it.
The twist throttle broke when I was far from home. Stuck on like 1/2 power. Its under warrenty and another is on its way. Its a hall effect motor.
My question is can I cut wires to throttle in an emergency and splice a couple togother so atleast throttle is stuck on high? Which wires? I have break cut off's to stop motor.
on website i bought kit from it says this about hall effect motors.."As the throttle is twisted, "Hall Effects Sensors" read the amount of voltage, and send this amount of voltage to the controller. 5 volts means the controller does nothing: sends no pulses to the hub motor, 0 volts means the controller sends electrical pulses to the hub motor as fast as it can."
Does this mean I just cut all wires to throttle and throttle will be sending a 0 volt signal so motor will be stuck on high?
Thanks,
Kenny
Thanks,
Kenny
