Just_Ed
Tried again this morning and ..NO GO !
Kept messing around and found there is an intermittent short in the key switch. I bypassed the switch with a shunt and everything works as it's supposed to.
The not-so-good noise is coming from the chain meshing with one of the gears. The teeth on the special order gear apparently aren't thick/wide enough. The chain wants to wander from side to side. So (not sure yet), but it looks like there may be a change out of that gear.
I had a hard time getting that gear in the first place. Hope I have better luck this time.
