Just_Ed
Thanks for the suggestion Hillhater.
Looking at the video, it looks like the cylinder he is using is a single piston dual line cylinder for two brake lines...right? That may be OK, except (correct me if I'm wrong) my cylinder has two separate chambers, (3 ports) thus if I lose one line, the other line is still functional. I'm blocking one port on the dual port side.
That being the case I would need two of them for my system which is what my set up requires. The difference is that I'm using a 3 port cylinder opposed to his 2 port cylinder.
Why? Well I needed to order another complete set to include the master cylinder, lines, calipers and disc to complete my set up for 4 wheel braking. Also, I needed another 'rear' caliper that came with the parking brake set up.
So two dual-port master cylinders will be required...one for the front two brakes and the other for the rear two brakes.
