C discharge rate
renago
next week I will finally have almost all components for my first e-bike .
BUT......
I am very unsure on which batteries :|
the bike will be used for fun , 90% off road , single track , on hills.
motor Cry ht 3525 .
Lyen controller, 18 fet .
I was thinking to have aprox 15-20 Ah of capacity
which battery shall I use ????
the dilemma is between RC Lipo , which C rate ?
is 20-30 enough or shall I go higher ?
and A123 20amp HD-A , will they give me the right kick when I need it with just 3C ?
any suggestion is very much apprecieted
Renago
To determine what C rate you need, find the max amp draw of your controller. Now divide it by the AH of the battery capacity you plan to get. Example:
40A controller with 5ah battery; 40/5=8C battery
40A controller with 10ah battery; 40/10=4C battery
40A controller with 20ah battery; 40/20=2C battery
AH times C rate gives max amp output.
So 20ah of 20C rated baatery can provide a 400A output.
ok, this is clear , but which type of battery would you choose , Rc lipo , or A123 ?
renago
For that kind of ride, I've been very happy with 20-30c turnigy lipo. 20 c zippy hasn't been near as tough. Definitely more sag with zippy that low c rate.
If you have the coin, go for as much c rate as you can afford. I have found carrying more than 10 ah of 72v just leads to too long a ride that melts the motor.
So 10 ah carried. Come back, let it cool, then slap on more or wait for a recharge. Charge and cooldown about the same time if you have a decent charger. (300w or more)
having a capacity of 15Ah , doest mean I must ride full throttle all the time .
in most cases the track is difficult so the average speed in motorcycle is only 25km/h .
in some point we speed up till 80km/h , but this is very short .
mainly I need the power to make some short acceleration, or climb steep and rough tracks .
heating up , I hope won't be a problem , otherwise I will install a water cooling system .
of course the higher capacity will stretch my range , hope to reach 70-80km , hope .
so you guys will suggest a 30 C discharge rate .
but no one answered about A123 or RC Lipo ???
no one is using A123 since the chinese have saved the company ?
Renago
....in some point we speed up till 80km/h , but this is very short .
.... I need the power to make some short acceleration, or climb steep and rough tracks .
...... my range , hope to reach 70-80km , hope .
Renago
I fear your combination of expectations is a little optimistic !
Steep climbs on rough tracks is not suited to a hub motor configured for 80km/hr road speed.
80km range will need more than 15Ahr !
A123 is going to be difficult to get the C-rating that is available in RC LiPo
Interestingly enough, I am making a very similar setup:
Norco VPS
HT3525
18FET Lyen 4110
Battery: 24S2P RC LiPo - 8 x 20C 6S 5000mAh Turnigy. Which should allow me to do 20C * 10Ah = 200A at 100V. Which is 20kW... way more than my controller / motor will handle.
So based on the size packs that we are making with these RC LiPos, even 20C is plenty POWERFUL.
renago
A123, for me.
But its like asking how long is a piece of string.
Do you have a tab welder? Can you solder? Do you know about LiPo and associated risks and precautions?
If cellman was still in supply of round cells, an a123 pack would be a fantastic idea. There is a pretty good looking used pack for sale at the moment, in the USA.
But for trail riding, I wouldn't want to pack the weight of a 20 ah a123 pack over 36v.
Don't listen to me, I have no experience with dirt riding, or hubmotors. :wink: Go melt your motor, it's fun! :twisted:
I live in a hot climate, it's true, but half the motors I melted have been done in winter. :mrgreen: When I say hill dirt riding, It's a rocky mountans hill. So I can melt a motor in 40 min anyday I choose to. I just found that with a 10 ah 72v size limit, still a hefty 700wh, I tend to head for home just before I melt one down.
Much much much more importantly, the dirt bike doesn't handle for shit because I carry 20 pounds of battery.
I think I'll go for the LIPO , at least on my first bike.
there is also a second in the pipe line , with a central motor.
the experience on the first one will a good learning curve .
Renago
Renago
Remember that LiPo is a Lifestyle. You probably won't go back, and it requires that you take your batteries seriously. Attention to detail is requisite
