teslanv
The spreadsheet doesn't reflect your comments. Can you include the one you are referring to.
Bicycle sprocket diameters:
____inches__mm
40T = 6.4___163
42T = 6.7___170
44T = 7.0___178
46T = 7.4___188
48T = 7.7___196
50T = 8.0___204
52T = 8.3___211
54T = 8.6___219
56T = 8.9___226
58T = 9.3___237
60T = 9.6___244
Are you using a Nuvinci N171B Autoshift developer's kit with a standard manual shift cable? - Because the the shift ratio is very different from the Autoshifter and the Manual Shifter, and a manual shifter will only give you about 1/4 the gear range of the autoshifter.omnivore said:teslanv said:The spreadsheet doesn't reflect your comments. Can you include the one you are referring to.![]()
that spreadsheet that I posted with my last comment has the correct input numbers. the real world output is for some reason incredibly low.
I'm not saying your spreadsheet is wrong. I'm saying something is wrong on my end. It has so many low gears and basically no high gears. I'm almost done turning the twist shift when I finally feel it kick into a high gear and give some resistance on the pedals. Otherwise I'm riding at very low gears and the motor just SCREAMS and I can't help it at all. I can go from about 3mph to 24mph that is my speed range running through the gears.
As is it beats walking or riding in the heat, but it's more dangerous for me to be going slower than traffic here. I take as many alleys and side streets as possible but our streets (main,side and alley) here are awful and damaged throughout. It's like a vibratory cleaner, I used to have to go through and tighten everything up on my mopeds after every few days of riding or things would start falling off of them.
I may end up just taking it off and putting it onto my singlespeed and going back to simple cassettes on this bike.
I've restored his last post (above). The only clue seems to be at the end of that :?Hillhater said:Pretty poor approach to delete all posts.
What caused that ?
omnivore said:.... Seeing most of my posts with 4-500 views and 6 or 7 responses I guess is just pretty obvious that I don't belong here......
